I figured I would ask this here since the frame in question seems to be fairly popular for commuter builds.
I would like to use a triple crankset with a 53t big ring. (I know nashbar says 48 max.) The problem I am running into is the FD (SRAM X.9 low clamp bottom pull) I wanted to use will not clear the rear tire(700x35) when positioned for the height of the big ring.
One variable is that the FD is a 34.9mm that I was planning to shim to fit the seat tube
I guess I am looking for FD recommendations that are known to work with this frame and a 53t big ring. But other solutions are welcome.
The way I see it my options are:
Compatible FD if available
Going to a 46/36 double
Others?
Others?
