32 years mountain biking, wrenching on my bikes for 25+ years, former master mechanic.
But this has me stumped.
2018 Trek Top Fuel, boost, 1x 11 drivetrain, XT shifter, SLX clutch derailleur.
Driveline is perfect. Shifts great.
High limit, low limit and b-tension are properly set.
Occasionally, the the rear wheel is removed for transport or whatever. I'll disengage the clutch, remove the axle and pull the rear wheel.
Sometimes when I put the wheel back on, shifting is trashed. There is severe drag on the drivetrain, regardless of clutch engagement, and the shift detents are completely misaligned.
It won't shift into the two smallest cogs, and it overshifts to the largest cog, dropping the chain into the spokes.
I'll pull the wheel and put it back on once or twice, and it is completely normal.
W.T.F!
I thought the wheel wasn't aligned, but that doesn't seem possible with the through axle.
I'm thinking it may have something to do with the clutch (will clean, lube and adjust today), but that doesn't make sense either, as it only limits forward motion.
Help me Obi Wan Bikeobi, you're my only hope!
Bob
W.T.F!
Bob
