1 - 2 of 2 Posts
I've run across a problem with some forks and wanted to know if anyone has had similar problems. I've noticed on some forks (currently a RS Duke XC) when you corner hard, the rotor will rub. I assume this is flex in the fork/front hub. I am able to make it a little better by tightening the front skewer super tight, but it will still rub a bit. Has anyone else had a similar problem and/or have a solution?
Please note that this is not the same issue as the rotor rubbing after you remove and reinstall the wheel. I can see a nice gap on both sides of the rotor when the bike is stationary - the rubbing will only happen when you corner hard.
1 - 2 of 2 Posts
