1 - 14 of 14 Posts
Very nice, needs a red alu pinch bolt.
As for chainstay protectors, I use black cork bar tape and insulation tape at both ends to keep it in place.
Banned
...all that work and you run that electrical tape thing and Nokon shift housings which is heavier than 0815 Shimano:nono:
Nice! Where'd you get the nylon bolts and what size are they? You think its ok to drill holes on some parts of that parallelogram/body?
Discussion Starter · #13 ·
culturesponge said:
very nice work, good use of nylon bolts + looks like you ride your bike as well
...you should upload some wider shots of your bike on the "Post your light-weight bikes!" thread
bike is not finished, I will post it at the time...
it is 10.9kg Blur X4 for aggressive riding with Minute MRD 100mm thru-axle, XTR M970 cranks with chainguide, tune King MK/Kong hubs (rear modified for thru-axle), R1 brakes...it will be lighter, but still strong...
Discussion Starter · #14 ·
jordanrosenbach3 tell right...
I dont drill holes in alu parts, only make its more slim...derailleur still stiff and I thik strong enough for technical riding...
1 - 14 of 14 Posts
