Being a Horst-link believer for so long, and that being a major reason for the purchase of my 5 spot, I was quite saddened when the news of TNT broke. Slowly the speculation gave way to reviews by many Homers whose opinions I have come to respect over the past couple of years. I began to come around in my thinking. Maybe the HL was all just marketing BS, after all the world is full of it.
I had to find out for myself.
My review-
I won't go into too much detail on the many areas that my experience paralleled that of the previous reviewers.
Braking- Noticeable lack of extension in the rear when braking only with the rear brake, at first I thought it was squat but after watching the shock I found it wasn't compressing. This did indeed give a stablizing feel, if traction was affected I couldn't feel it.
Cornering- Stiffer rear end, despite the argument of others, I do not attribute this to the TNT rear being new and the HL old. When braking into a corner the bike felt more balanced front to rear, I'm guessing this is because of the lesser amount of extension in the rear. I can't say for sure what the reason, but the TNT felt better in the corners than the HL did.
Pedaling- A firmer feel on the TNT, maybe less compliant would be a better description. After returning to the HL after three weeks on TNT, the HL felt smoother on small bumps. I think the TNT may pedal better while standing and mashing but I can't say for sure.
Now there was only one real test left to ease my worries about the prospect on my HL being replaced with TNT.
Steeper, looser, and longer than it looks in this photogragh, this section of tight singletrack is unforgiving when it comes to traction, front end lifting, and if even for a second you lose your line.
Whenever I make changes to my ride, stem length, new fork, saddle postion and so on, I use this hill to see what effects it will have on super steep loose climbs.Over the past year and a half I have gome from a 110mm stem down to a 50mm, 110 to 100, 100 to 90, 90 to 70, and finally 70 to 50. Each stem change significantly changed the body position required to make this climb. The same held true for the switch from the Vanilla to the Marzocchi, the slacker head angle really made me work to get up this hill. But with every change if I just gave everything I had and stayed forward the rear end would hook up flawlessly and I'd power up it. Only on one occasion did I have to make a second attempt to clean the hill, this was after the 70 to 50mm stem length change, which I guess just caught me off guard. Bottom line, if I can still climb this hill with TNT, then all is good.
On the first day attempting this hill with the TNT rear I failed 14 of 14 tries. I was crushed, and exhausted. I drove home after the beat down wondering what the hell could have been wrong.
Two days later I went back, angry. That f-ing hill was mine.
Nope, 8 tries and 8 failures.
Every possible adjustment was made to make it up with the TNT rear, shock settings, pressures, body position, full out mashing on the pedals, steady cadence, you name it.
My conclusion as to the reason for failure; I was unable to keep the front end down and maintain traction at the same time. Was the rear squatting under power? It felt like it. Did the rear end hook up as well as the HL? No.
I went back the next day after reinstalling the HL rear and made it up on the first try usual.
I'm sure that by making adjustments to my ride that I could make it up with the TNT rear, but those adjustments would surely have a negative effect on descending.
I'd be very interested to hear other Homer's experiences in similar conditions. Basically find a super steep and loose granny gear climb, and see if you too can't feel a difference in favor of the HL.
My review-
