1 - 20 of 20 Posts
Spanish biker
Hi, here my new triple light, very, very easy of doing, how you can see, I hope that like us :)
I have used a square tuve of 40x40mm and PVC tube of external diameter of 40x40mm too.
Now glued the PVC tubes to the aluminium tube
Inside view, I have used too a "custom" inside heatsink how you can see
Glued the 3 leds to the aluminium tube (I have used 2 Cree Q5 and 1 Cree P4, I know that have was better use R2 leds, but was that I had :D )
I make holes in the square tube and I have soldered the cables...
Now I have solder the cables to the swich, drivers and power conection, I have used 3 drivers to can use a battery of only 7,4 volts :)
Another view
Rear view
Another view
Power supply put on the tube
Inside view
Switch put on the tube
Inside view
I have isolated the driver with....(sorry, but I don't know how it say in english "manguera termoretractil") :madman:
Another view
Another upper view
Bottom view, I have used a H-24 spacer from Cateye
Front view
Well, I still don't have ended the light, already don't have put the lateral caps, but I hope ended soon and put any beamshot :D
Greetings - Saludos
msxtr
Spanish biker
Discussion Starter · #5 ·
cytoe said:
Those look like Kennan drivers. What are you powering them w/? I've had 3 die on me:(...I miss the old design.
Yes, are the "new" kennan drivers
And I have used this drivers in several DIY lights and work perfectly....I use a Li-Ion battery of camcorder of 7,4 volts to powering...
I had a "old" kennan driver and die too....I think that this drivers are better do than the olds...
Greetings - Saludos
msxtr
Nice big 35mm? optics and individual drivers, it should be nice and bright.:thumbsup:
Another request for beam shots please, outside on the trail would be nice.
manguera termoretractil = Heat shrink;)
Spanish biker
Discussion Starter · #17 ·
troutie-mtb said:
:thumbsup: that is bright :thumbsup:
can you switch 2 lights off and do a shot with just 1 , then 2 , and we have seen 3 .
Nice work
For now I think that will use the light only with 1 switch to all leds, maybe that in the future I change the configuration to switch 1, 2 and the 3 leds...:smilewinkgrin:
Now beamshot in the country
Greetings - Saludos
msxtr
Spanish biker
Discussion Starter · #19 ·
troutie-mtb said:
Nice Pic :cool:a very usable beam maybe it could do with an optic swapping for a flood to fill in the near ground .:idea:
Hi, I normally use too another light with more flood beam, with the both lights I get a excellent beam of near and far :)
Greetings - Saludos
msxtr
1 - 20 of 20 Posts
