here is a list of the components :
BOTTOM BRACKET: Shimano Sealed Octalink
BRAKES: Tektro Auriga Comp Hydraulic Disc Brake, Twin piston
CASSETTE: SRAM 9-speed Index, 12/32T
CHAIN: Shimano 9-speed
CRANKSET: Shimano Hyperdrive, 44/32/22T Alloy inner rings
FORK: Rock Shox Dart 3, 100mm travel
FRAME: GT i-Drive 6061 Aluminum Full Suspension Frame
FRONT DERAILLEUR: Shimano Deore
GRIPS/TAPE: GT Lock Down, Co-molded Locking Grip System
HANDLEBAR: GT Riser Bar, 6061 Oversize w/ 10 degrees sweep, 4 degree rise, 35mm rise, 680mm width, 31.8mm clamp
HEADSET: FSA Mallet w/ Chromoly Lower and Oversized Lower Sealed Bearing
LEVERS: Tektro Auriga Hydraulic
PEDALS: MTB Alloy body w/ Steel cage, Toe Clip adaptable
REAR DERAILLEUR: SRAM X.7
REAR SHOCK: Rock Shox Bar 2.1
SADDLE: SDG Bel Air
SEATPOST: SL Alloy Micro-Adjust
SHIFTERS: SRAM X.5
STEM: GT 4-bolt face w/ 3D forged extension
TIRES: Kenda Nevegal, Front: 26 x 2.3"; Rear: 26 x 2.1"
WHEELSET: Rims: WTB SX-24 Disc, 32H, Black anodized, for Presta valve; Front Hub: QR disc w/ sealed mechanism bearings; Rear Hub: Shimano Disc
