Build Info
Slobberdoggy said:
Yup, I considered this frame as well. Very cool frame. Just out of curiosity how much do you weigh and how tall are you? The frame is fine no matter what just wondering about the how the rest of the build will be. V-brakes I presume?
I'm 5' 11" 190# The frame is a 20" with a 610mm top tube after coming from a Rocky Mountain Element Tsc Full Suspension I was really impressed so far with this frame ( only one ride)
I think the scadium along with the s curved seat stays take some of the edge off !
Here's the build as of today !!
2005 Orbea Scape 20" 1391g
Brake Bosses 18g
05 Rock Shox Reba Team w/ star nut 1605g
Poploc 50g
FSA Orbitz Z 91g
Stem Ritchey WCS V3 110mm w/ Ti Bolts 101g
Easton CT2 Flat 580mm w/ alum Plugs 134g
Ritchey WCS Bar Ends 98g
Grips ESI Silicone 44g
Brake Levers
Rear Avid 04 SL 76g
Brakes
Avid 04 SL 167g
Juciy 7 carbon 294g
Juicy 7 Rotor 116g
Rotor Bolts qty. 6 13g
Rock Shox Adapter 14g
Adapter Bolts Ti 6g
Gore Shifter Cables 100g
XTR Rear Brake w/ Full Housing 70g
XTR Shifter 254g
Chain Shimano CN-7700 XTR 273g
Pedals Crank Bros. Triple Ti Short Spindles 179g
Cranksets Race Face Deus w / Race face rings 825g
Derailluers
XTR Rear Derailluer M-960 203g
XTR Front Derailluer M-961 w/ Ti clamp bolt 147g
XTR Cassette M-960 8 speed 12-34 233g
Wheels
Mavic 717 / XT Disc 853g
Stan's ZTR 355 Hugi 240 DT 14/17 756g
Rim Tape
Stans rim Tape 2 g
Front Rim Strip Nylon 15g
Skewers
Shimano XT 60g
Bontrager Ti 46g
Tires
Specialized Roll X Pro WSD 530g
Kenda Blue groove Lite 470g
Tubes
Stan's Rim strips 57g
Stan's sealent 30-35 grams per Oz. 60g
Torelli Extra Lite 125g
Saddle San Marco Aspide "Night Train" 150g
Seat Post Thomsom Master Piece 27.2 X 330 190g
Seat Binders Orbea w / Ti Bolt 15g
Misc.
Specialized Rib Cage Pro w/Ti Bolts 36g
Zip ties 2g
9874g
21.77 lbs.
*** It weighed 9870g / 21.75 on my Alpine Hanging scale *****
These are the parts that I have on the way;
Stan's olympic disc / DT240 center lock/ sapim CX Ray
Tune Bar Ends
Tune Skewers
Stan's Rotor
Syntace 90mm stem w/ Ti Bolts
This will bring it down to 20.85 lbs until I put the rear disc on ! I was not to happy about the weight of the Juicy 7 carbons Total with the adapter was 443 gram but with a 116 gram rotor!
