I'd rather use the 15mm then an allen.
so... 15mm wrench?MiniTrail said:allen wrench in the end :skep:
Look at the threaded end
louisssss said:so... 15mm wrench?
Exactly what mine weigh.louisssss said:They weigh in @ 296g. (is this similar to what the rest of u guys got?)
You should probably invest in a pedal wrench, for now and the future.louisssss said:maybe i will
ahhh ok, i only use TIME pedals so ive never ran into that problem. gearwrenchs are also thinner than something like craftsman wrenchesBlownCivic said:Regular 15mm wrench is almost always too thick to fit in the space on the spindle. Pedal wrench is usually quite a bit thinner than a regular one.
A regular old wrench has worked on all my bikes so far.superspec said:whats wrong with using a normal wrench over a pedal wrench?
