It's a 2006 Gary Fisher PHD frame, size M.
The build list:
Pike 426 coil-u-turn fork.
Mavic 325 rims on Dimension hubs - the rear hub is sweet, it rolls on 4 cartridge bearings, the freehub uses 4 pawls, and has a real low degree of rotation between clicks. I'm running a 10mm thru axle to secure it.
2.3 Kenda Small Block 8 tires.
Avid Juicy 5 brakes 160mm rotors front and rear.
X9 short cage rear derailleur.
New X9 trigger shifter (like the X0)
Shimano Ultegra 12-27 cassette.
Shimano XTR chain.
Bontrager King Earl cranks.
Truvativ Howitzer bottom bracket.
32T e13 guide ring chainwheel.
e13 32 special chain guide.
Tioga MX Pro pedals.
Cane Creek XC flush headset cup on top to keep the bars low, and the regular XC reducer cup on the bottom to keep the head angle I wanted.
FSA FR270 bars cut to 25"
FSA FR270 50mm 6deg. stem.
SDG saddle.
No-name seatpost.
I love it! - with the Pike at 95mm and near full compression damping, it's really dialed for jumping, and this frame is super, super easy to manual. With the fork at 140mm it's amazing the rough stuff it can go through - no problem doing some "stunts and freeride stuff" with it.
The build list:
Shimano XTR chain.
SDG saddle.
No-name seatpost.
