SuspectDevice said:
FTW has always told me that closed gussets on Alumiun are a no-no, just like they are on steel. Intense stuff is 7000 right? That means it just gets baked, not heat treated. Even on a 6000 frame I think it's a good idea.
The only aluminum bikes I've ever seen with closed gussets are Kastan's... And intenses, and hell those thumbnail gussets are usually welded on crooked! Pinning the whole thing down tends to "draw" the gussetted tube together, which can lead to weird alignment issues and IMO, the less welding the better, even if you are working with a downtube that is what, .065?
Glad to see this guy has better aim than the old production welders at Intense!
Remember Aluminum melts at 1000 degrees , so even baking has a much differnt effect on the meatl than say jsut tossing a steel bike int he powder coat oven.
The bikes I have exsperince with are the 7000 series frames , these as I believe only get baked at 500 for a short time .
Some 6061 alloys can be solution heattreat , similer to what Cannondale does to their frames these accully age after time also .
I guess what I was orignally getting at is the main reason you leave the ends of a gussett open on steel bikes is partly to let stress escape , but also it has to do with heat effected zone and how the steel tube will will dent or even crack when a over heated zone is put under excess stress from a gussett .
On aluminum this theroy is differnt as the gussett your welding on basically becomes a external butted section of the tube , the heat effected zone has no bearing once the frame has gone through proper heat treat , due to the low melting point of aluminum .
So really again the only real thing you need to remember is that the gussett dosent increse the load onthe aluminum tube , streess escaping has no basis here as the material reacts differntly than steel .
