Y get two controler and two r5 led from dealerextreme , a set of bottoms , o rings , 4 batterys 18650 and a heatsink thermal . I get one dual head magicshine
http://www.dealextreme.com/p/5-4mm-...dapter-y-cable-for-sku-29489-30864-25cm-32753
to do all the conections , just cut the two female and use it to put the leds . One female reused to the battery and the other one to back up for other lights .
The leds are this ones....
http://www.dealextreme.com/p/cree-xp-g-r51b-7000k-350lm-emitter-with-16mm-base-44306
And the boards.... this one . it work at 1200 mah maximum , so it dont get burned of hot at max power.The led can work at 1500 .
http://www.dealextreme.com/p/3v-8-4...cuit-board-for-flashlights-16-7mm-6-3mm-26108
One switch for on and for change the modes ........
http://www.dealextreme.com/p/clicky-switch-for-flashlights-11mm-5-pack-5588
Thermal of course .
http://www.dealextreme.com/p/heatsink-thermal-compound-grease-like-4593
Somes o rings , to seal the light .
http://www.dealextreme.com/p/water-tight-o-ring-seal-21mm-20-pack-5634
A 4 batterys ..18650 standar .
The battery are solder 2 in series and 2 in paralel so i get a 7,4v and i can charge with the same charger of the famous magicshine that i have one .
The mount of all is very easy , dismount the flashlight , and cut the midlde body to reuse it as close of the light . solder the led to the controler and put in the middle two 1c coin with termal paste put a o-ring in between the cristal of the flashligh and the reflector , insert the led-control inside and you have the easy parts .
Now the closer . You must to solder a small spring ( i cut from the flashlight) to the positive cable and some amount of solder to the negative and it too the border of the body. To have all the parts in its place i use a termal silicone .
I must to take some pictures.....
So now you can thread both parts and the light is ready .
