Huh. I find that hard to believe.
Congratulations! Always nice to lose that much weight at once, but from here on in it gets tougher and tougher.evan811 said:Any ideas to loose some more would be great!
Probably a wheel set would be a good idea.
You can get Sun EQ21's on XTR hubs with DT Revolution's on CRC for pretty cheap. Should be 375-ish. I know with Hopes it's $310 or so, free shipping.evan811 said:I still run 8 speed, so higher end parts are somewhat limited, but from time to time items come up on ebay.
What wheel sets would everyone suggest for someone on a budget?
If your rear hub takes an 8-speed cassette, it'll also take a 9-speed cassette, so you could replace your rear shifter with a 9-speed shifter and then move up to an XT 11-32 9-speed cassette, which is lighter than your 8-speed all-steel one. If your old chain has lots of wear, then you'll want a new chain at the same time.evan811 said:I still run 8 speed, so higher end parts are somewhat limited
