1 - 13 of 13 Posts
Hi all,
I know it sounds retarded.
My shimano shoes when clipped in will rub the front fenders during the spins when I am making a turn. After taking off the fender, it still rubs the tire.
The clipless metal plate under both shoes are already installed so that both shoes are "pushed" furthest on the pedals.
Please tell me what's wrong, and what I can do to correct it... Thanks!
Advanced Slacker
menuhin said:
Hi all,
Is this bike a 29er?
This is known as "toe overlap".
how long is the top tube? and what is the size of the bike? sometimes on smaller frames you get some bad toe buzz and thats what it sounds like to me. i dont know if there is anything you can do...
~Disc~Golf~
ok here's what you need to do...
clip in to your pedal and rotate the crank so it's at the 3-o'clock position (most forward). Line up the tire along your shoe where you're making the most contact. Then, with a sharpie, mark a line on your foot minus about a 1/4 of an inch behind your tire (the area where no contact would occur). Then, with a hack saw cut off the front of your shoe/foot following that line. You may need a stick to bite down on. Then, with a blow torch, cauterize your foot but be careful not to melt your shoe.
repeat process for the other side.
I hope this helps.
Old man on a bike
Compromising your foot's optimal position on the pedal to avoid contact isn't a great idea unless you're willing to try highdell's method :eek: Small frames and large feet can sometimes create contact, though, especially small 29ers...whatcha got in the way of setup here?
Advanced Slacker
menuhin said:
It's a cyclocross bike with a more road-bike like geometry. Maybe therefore the toe overlap is greater.
Toe overlap is not uncommon on road bikes. It happens on some 29er mountain bikes, it really depends on the frame and/or fork.
I have a little but of overlap if my feet are at 3 o'clock on my 29er mountain bike. In reality it is not an issue on the trail.
My road bike has a LOT of overlap. I have to pay attention to where my feet are on a slow tight turn.
There is nothing wrong with your bike. It is called toe overlap, which means your foot will overlap the front wheel.
Many bikes have it, and it is normal. One thing to consider is this: while you are traveling over 10mph, you will never turn the wheel so much that your foot could make contact with the wheel. Only slow speed turns with be an issue, which you will learn how to deal with.
However, I would readjust your cleats to a "normal" position, on the balls of your feet. You do not want to move cleats to accommodate your toe overlap. You could injure yourself that way by having badly positioned cleats.
menuhin said:
Hi all,
Maybe this is your problem? Nice shoes. I'm just kidding.....that's the first thing I thought of when I heard your problem.
1 - 13 of 13 Posts
