1 - 8 of 8 Posts
A little of everything
Just above the BB in the weld on the gusset. So I'm going to get a new frame. Which one?
A Heckler in Trans Red with a 5th element air :eek:)
Just ordered a Maverick fork and some Hope Mono M4 brakes too.
With fat tires we are looking at about 11kg with 150mm front travel and 130mm travel in the rear.
I'm getting the frame tommorow and the other parts a bit later.
I'll post pics when it's finished.
On your left.
what did Santa Cruz do for you?
Are they sending you the Heckler as a warranty replacement?? I think the Heckler is a great choice for harder riders. It does weigh a little more, but is just so nice and stout. If I break my Blur I'd consider a Heckler for sure. With the Maverick, you've got a frame and fork that weighs within 1/2 pound of a Superlight with Fox F100X, from there it's just a matter of components.
A hopped on pop.
what year is/was your blur...
just curious. i think the '02 blur frames had some type of design or manufacturering flaw (something about a butted portion of the frame tubing being to thin)??? i think this was very prevalent with the 02 large blur framesets.
cheers!
the heckler.maverick/mono m4 set up already sounds killer.
Discussion Starter · #4 ·
The distributor in Denmark had both a Blur and a Heckler in stock, so I choose the Heckler. This frame will also fit the Maverick fork perfectly I'm 88kg and ride heavy gears, that might also have something to do with it cracking. Or maby just a bad weld?
1 - 8 of 8 Posts
