Hello WW's. Iv'e lurked on this forum for a while now and posted my bike here and there but figured i might as well start a thread of my own. I wouldn't call my self a "weight weenie," i would say I'm more weight conservative. Every part on this bike has had at least three others before it, in other words, i like to try new parts a lot :thumbsup: The lightest ive had this bike is 19.4 which was last year, but i was running a completely different spec then, and the heaviest at 24lbs which i keep it at when i train.
Bar Ends: N/A
Bottle Cage: King Ti
Bottle Cage Bolts: Black Aluminum
Bottom Bracket: 2007 Shimano XTR M970 73mm
Brake Levers: 2011 Shimano XTR M988 BL-SL Trail (Ti bolts)
Brakes Rear: 2011 Shimano XTR M988 BR-FB Trail (Ti bolts)
Brakes Front: 2011 Shimano XTR M988 BR-BB Trail (Ti bolts)
Cables / Housing: Shimano XTR M970 Teflon Housing
Cassette: Sram XG-999 11-32 cassette w/ Chris King Ti Lockring
Chain: Shimano XTR/ Dura Ace M970, 9 Speed w/ KMC quick link
Crankset: 2008 Shimano XTR M970 175mm 1x9
- Crank Arms: Shimano XTR M970 175mm
- Crank Bolts: KCNC Aluminum
- Outer Ring: N/A
- Middle Ring: MRP 104mm 34t Single Non-Ramped Ring
- Inner Ring: N/A
- Ring Bolts: KCNC Aluminum
Derailleur Front: N/A
Derailleur Rear: 2010 Sram XO Short Pink LTD, Ti Bolts, Carbon back plate
Fork: 2010 Rockshox Reba SL Team Black
Frame: 2009 Santa Cruz Blur XC Carbon, Silver, Medium
Grips: ESI Chunky Black, cut for shifters
Handle Bar: 2010 Easton Monkey Lite XC, 31.8mm/27.5 inches
Headset: 2001 Chris King No-Thread-Set Black, 1 1/8, Ti bolt
Pedals: 2011 Shimano XTR Race M980 SPD
Quick Releases: eBay Steel Bolt-Ons
Rear Shock: 2010 Fox RP23 Boost Valve, w/ Pro-Pedal, Ti bolts
Seat: 2010 Selle Italia SLR Kit Carbonio
Seat Binder: Extralite Ultraclamp, 34.9mm, Ti bolt
Seat Post: 2010 Gravity Dropper 4” Turbo 30.9mm/350mm, Ti bolts
Shifters: 1999 Sram Plasma 9-Speed Grip Shifter, Aluminum bolts
Stem: 2010 Edge Carbon 70mm XC Stem, Ti bolts
Tire Front: Schwalbe Nobby Nic 26x2.25 Evo SnakeSkin
Tire Rear: Schwalbe Nobby Nic 26x2.25 Evo SnakeSkin
Tubes: Stans Race Tubeless System
Wheel Set: 1490g
- Rims: Stans ZTR Olympic (stickers removed)
- Spokes: Sapim CX-Ray
- Nipples: DT Swiss Aluminum
- Hub Front: 2008 Chris King ISO Disc 110mm
- Hub Rear: 2008 Chris King ISO Disc 135mm
Misc Option: Lube, Paste, etc
Weight in this spec: 23.2lbs
When i race i take the gravity dropper off, switch to racing ralphs, run tubeless and sometimes mess around with gearing. I also just ordered an mmx wheelset for races
with this setup i should be at around 21.3ish. This bike gets ridden 3-4 times a week.. every week.. this is no show bike and yes i know its dirty
Comments, questions and opinions are all welcome...
Bar Ends: N/A
- Outer Ring: N/A
- Inner Ring: N/A
Wheel Set: 1490g
