1 - 5 of 5 Posts
Lay off the Levers
phoeneous said:
Does this fork support both v and disc? Does it come with the v brake mounts/studs? Thx. :)
According to the Zoke website the fork comes with removeable post mounts and a fixed disk brake tab. I have the '02 MX-Comp and it had the removeable posts in the box and plastic caps over the mounting holes. The '05 manual suggests the same is true now. You could call 'Zoke to be sure but I think the answer is yes.
Yes it comes as bikezilla said....
with the filler caps mounted in the fork and brake posts in the box. You can go either way with this fork.
Good Dirt
1 - 5 of 5 Posts
