C.M.S said:
What is conciderd sweet n light in grams when looking for tires for very light wheel set ?
I have 2.2s in mind , any suggestions in weght..
For a true 2.2" tire 400 to 450g is considered light, 550 to 650g is considered average. But keep something in mind, lighter isn't always better. The heaviest component in any tire is rubber. So the first thing that gets reduced when a manufacturer goes to produce a light weight tire is, you guessed it, the amount of rubber used to make the tire. The results are thinner casings and tread caps. This results in a much less durable tire, more susceptible to sidewall tears, punctures etc. Using a higher thread count in the tire casing can help with this, but only to a limited extent. Also very light tires often compromise in the tread department as well. Most will use very small and low tread blocks. This serves two purposes, it lightens the tire a bit and tends to reduce rolling resistance. But it can also sacrifice traction as well.
The key to tire choice involves not just weight, but terrain as well. An uber light racing tire is fine for buff single track with few rocks, roots, etc. that are likely to tear up a sidewall.
So if you ride in an area with few rocks etc. Go ahead and go as light as you can find. Otherwise be prepared to compromise a bit on the weight for a bit of added durability. A very good tire that I've used is the Schwalbe Nobby Nick 2.25" TL Snakeskin at 580g +/- 10g. They are reasonably light, roll very well, and have good traction in most conditions. Not the lightest 2.25" tire out there, but certainly not the heaviest either. And they do resist cuts and abrasions well.
Definitely your call. But do take into consideration the terrain that you ride. While a super light tire is fast and fun to ride, it can also be an absolute night mare if not suited to the terrain.
Good Dirt
