MTB for first gravel event?
2054 Views 12 Replies 11 Participants Last post by  ddoh
Anyone jumped into the gravel races just using a full suspension 29er MTB with narrow, fast rolling tires?
I am getting the gravel race e-mails and know and read about it but don’t have a gravel bike.
It has some appeal to me and the local race scene has fizzled out, especially early in the year.
I was considering signing up and just riding my MTB. I have done road racing and MTB racing and some endurance races on the MTB. I know I won’t have the bike or youth to keep up with the main group on pavement or fast gravel so it would end up a long solo effort or perhaps grouping up with a few riders the last couple hours.
I thought it’s a lower cost way to try the event. There is the Shasta gravel race in Northern CA and the True Grit in Southern Utah. Have you seen others trying the MTB approach? Is it common to have a small group of people on MTB’s.
Thanks,
1 - 13 of 13 Posts
Go for it!
I participated in a number of gravel races last year on this, my 29er XC hardtail with 2.1” tires. Perfectly acceptable. The only place you may suffer is in high pace group settings or long downhills where you need the extra gears.
I’ve done gravel races where there were people on fat bikes. Go for it.
  • Like
Reactions: 1
Thanks,
run what ya brung fo sho! Be careful though, you'll like gravel racing and you'll be out 7K for a gravel race bike next season!
So if you have some narrower or low-profile type tires on a 29er, you can do pretty well if you have a light-ish bike with either no suspension or a lockout capability. There are advantages to a full gravel bike, but you can make up for a LOT with the right tires and these other factors and then work the peloton correctly. Your biggest disadvantage will likely be aero, when riding alone. As long as you are hanging with a peloton or working with someone, you can minimize these effects. If your tires are a little more meaty, you can do things like take more aggressive corners, cut inside the "ditch" when the route changes roads, keep pedaling and keep speed up when it gets rougher, etc. I've worked these things all down to a science with my fat-bike and either 4 or 3.5" tires to the point where I can finish top 10 overall in the races around 40 miles or so. With a lower profile tire, rolling resistance isn't bad at all on gravel and a lot closer than you'd think. On pavement...it's just as bad as you'd think on a wider tire. Gearing is a challenge, especially in keeping up with the gravel-bike peloton, that's one place where mtbs differ a lot from road bikes, because in mtb we never really travel like this or benefit from such a big reduction in aero drag, so we generally don't have the gearing on mtbs to take advantage of it. For this reason, it keeps my RPM up around 90-100rpm (and more at times) for extended periods which is damn hard. Not everyone is trying to win...or even embarrass a bunch of gravel bikes, so the gearing thing isn't necessarily important for everyone, just that the dynamics of gravel riding are most similar to road riding, so that's a good way to set your expectations.
There are always lots of people that show up on hardtails and FS mountain bikes IME. The more "serious" racers show up on gravel bikes obviously.
Again, it makes a HUGE difference if you can find at least one rider to ride the majority of the race with, switch positions, etc. Aero drag is your main enemy and being able to switch out makes for a nice relief and ability to drink, eat, rest, etc. Low profile tires helps, don't necessarily need super skinny IME, but low-pro tread is good to have.
That's me. They (the gravel bikes) start ricocheting off my 800mm bars when it gets to narrow doubletrack too...
Bicycle helmet Bicycle Bicycle jersey Tire Wheel
Bicycle Wheel Tire Bicycles--Equipment and supplies Crankset
  • Like
Reactions: 2
Not if ya don’t let him by on the final sprint :). Though I figured your aero mods would have helped more haha
  • Haha
Reactions: 1
I did my first ever gravel event back in 2013 on my (then) new Jet-9. I had some 2.25 Smallblock-8s on it. Rode with the suspension locked-out and ran the psi a little higher in the tires. You won't keep up with the guys on drop-bar bikes on the road sections with your mtb gearing, but if you're doing it for fun, hell yea, ride your mtb. There are actually a couple of courses that I do, that I'd prefer to ride a mtb.
I race mtb with a fast guy who uses a hardtail mtb for long gravel events. I think he added bar-end grips, and sort of aero tt type center stubby bar extensions too, - I imagine it would be nice to have a couple of different hand positions for the longer races/rides.
Depending on your cassette range to still allow for climbs, I would consider a bigger front ring if you're 1x, - if you're still 2x or 3x you're golden for gearing.
Go for it. I’m doing the same thing soon, first gravel race ever, and it’s going to be on my mountain bike.
As mentioned earlier, make sure you can lock out, or the bob will drive you crazy.
1 - 13 of 13 Posts
