1 - 15 of 15 Posts
· getting back into it...
Gore Bike Wear does something like this, although it's not going to be waterproof. Do a search for Gore Bike Wear C7 2in1. They've done this for a while now, product used to be called their Alp-X line, I think. Now it's C5 / C7 stuff.
That said, I think people can wear whatever tight bibs they like and wear non-lined baggies over them. More versatility there, and still allows you to use the style and functionality of a baggy.
Working for Hyperthreads, I can tell you our Mountain Baggy shorts are awesome. I've used for a couple years now, wearing them over bibs or shorts.
· since 4/10/2009
Actually, the issue is that the baggy shorts are dropping. I wear a G-Form MTB Compression shorts with padding (for protection against falls). This needs an outer-garment and with baggy shorts, the cinch point is always the waist which makes it just as uncomfortable as shorts are versus bib shorts.
Maybe I just need a onesie.
suspenders? before you think I'm kidding, I use a pair of ski suspenders in the wintertime with the particular "tights" I have that have a stupid high waist that doesn't cinch well.
· Registered
I know you stated you don't like the waist cinch point on baggy shorts, but have you tried a belt with some stretch? I've found the Arcade belts to be quite nice for this and hey have a very low profile buckle.
· high pivot witchcraft
I'd prefer a baggy over an indoor trainer style bib for summer. The airflow is good for the jewels.
Busy working on something with a manufacturer
I invested in a bunch of 7Mesh stuff this year. Not inexpensive, but no regrets. They may have beat you with your idea…
I know this is not addressing the OP's question, but I agree with the shorts over bibs suggestions.
My hot weather go-to bibs are these (obviously with shorts over top, unless you like the drag queen look):
For shorter rides, I also have these (under shorts), which are shockingly good:
Both options are incredible when combined with these lighter than air, tougher than nails outer shorts:
I also have these cargo bibs but these are reserved for cooler weather (with or without shorts over them).
· Registered
I'm aware of 7mesh. What I'm trying to get made isn't just the indoor bib with baggy shorts but a complete garment
· Don't be a sheep
Is there such a thing a MTB baggy bib shorts with water-resistant/tear-resistant fabric?
I have running bibs with baggies for over a dacade. Just get some safety pins and pin the shorts to the bibs so the baggies don't fall down. I put some duct tape where I'm going to pin the shorts to the baggies. I don't care about holes because I always used retired road bibs.
· Registered
Scott make a hybrid bike short. Maybe not quite what you are after but has relaxed fit around thighs.
My Patagonia shorts have looped snaps to connnect to bibs. So do a bunch of Fox shorts I have.
· CEO Product Failure
A few cycling bibs are now offering "cargo" or "enduro" options-which means the addition of stretchy mesh pockets. However, these do not check the durable requirement.
Best option is to use the padding/compression short of your choice and pair with a set of baggies. The most durable cycling shorts/pants/manpries I have found are from TwinSix.com. I have one set which have been in use for close to 8 years---there is noticeable wear from the saddle but otherwise, they're GTG.
I'd use a spray (ScotchGuard) for water resistance. Most true water resistant clothing is not stretchy.
  • Like
Reactions: Vance72 and Brad
1 - 15 of 15 Posts
