MRP Ribbon SL cut appoximately 4.8oz out of the 4.2lbs of the original Ribbon.
They talk about shorter stanchions (travel limited to 130mm), ditching the Ramp Control, and less oil volume.
Does anyone know if the damper and air spring internals have been shortened as well? Like, could you take a Ribbon SL, swap on a Ribbon CSU, and party at 160mm? It sounds like you'd essentially have a Raven, correct?
