Has anyone ridden one of these yet? I had a 26in one when they first came out and it rode really nice.
Elevated chaninstays are good on a 29er because they allow for very short chain stays.awai04 said:Nice looking bike, but ey, what's with the elevated chainstay? The last time I took a serious look at one was with the haro extreme in the early 90's.
Maybe it's my early morning coffee. I didn't like this design just because of the seat tube bening the other way. But my guess is it's designed for shorter people. This design creates a shorter top tube without toe overlap. The thing is that front deraileur is designed to run on a seat tube at certain angles so it got to come off the bb like that. But still you'd need a post with lots of set back20.100 FR said:Elevated chaninstays are good on a 29er because they allow for very short chain stays.
I like this design very much, but would have bent the seatube near the BB area the other way, like on a KM !!!
I had a 26 inch Mrazek years ago and the tt length is kind of tricky. When I had my post high enough I took a straight edge from the middle of the clamp to the bb and measured the tt from there and it was 24.3 not the 23.5 that is listed.Hexonxonx said:Maybe it's my early morning coffee. I didn't like this design just because of the seat tube bening the other way. But my guess is it's designed for shorter people. This design creates a shorter top tube without toe overlap. The thing is that front deraileur is designed to run on a seat tube at certain angles so it got to come off the bb like that. But still you'd need a post with lots of set back
So after bad mouthing that design months ago I can say
Front Deraileur mounted correctly -Check!
Short Top Tube - Check!
No Toe overlap - Check!
Minimize Chain slap - Check!
The only thing I can't figure out is if it's designed for shorter riders, why is the head tube length so tall. maybe that's a 20" and it's designed for a 400mm seat post. (Thompson laid back would de the trick).
Like I said. I haven't finished my coffee and I'm over looking something
I was saying that if you built that bike with 80 degree seat tube, the front deraileur wouldn't work like it should because the trailing edge would be tilted/rotated about the BB too far up. but then I guess the seat is still too far forward of the BB so you'd end up with a laid back seat post to push the reach back to where you begin.Walt said:But the bent seat tube doesn't create a shorter toptube in any useful sense. If that were the case, I could just build bikes with 80 degree seat angles, and 21" toptubes, and have no toe overlap. Unfortunately, since you still need to get your seat back far enough to be in your normal position over the BB, the cockpit would be WAY too long. Oddly enough, they list the seat angles as 73 degrees - which would mean TONS of toe overlap on every model except maybe the large.
The 26" version:olds_cool said:he's got a concept 29er in his possession now. doesn't have a seat tube. i'm guessing it is similar to their 26 concept bike, with normal chainstays and an a-frame type seat mast.
