Nothing to see here except a mid 90's Stevenson 'Psychosis'. Bombproof chromoly Full Suspension Bike with a Risse Genesis Shock and a Fox Fork. The back has 2.25 inches of travel and the fork has 3 inches of travel. It is super pedal efficient, great for square-edged bumps.
I think I have posted this before, but I made some changes and thought I'd share. Among the changes, I put a shorter 110mm stem instead of the 125mm one in the pictures. The bike handles a bit quicker and the reach is still adequate.
Notable parts include:
Power Post - Rigged and Modified:
Since I took these pics I figured out how to rig the Power Post so that a cable loop and a cable knarp aren't necessary. I used a dremel tool to make a notch in the activating lever, and hooked the cable head into the notch. I am running another remote lever now that just pinches the end of the cable so that the cable head can be attached to the seatpost itself. There wasn't enough spring tension to get the seat to come back to full pedaling height, so I rigged it with an elastomer that gives it enough spring strength to come back up with no problem. I'll have to take some pics of that and edit the post.
Avenir Bar-Ends: Quill-Style Plug-In Model instead of clamp-on style, saves bar space.
Drivetrain
17/26/39x11-13-16-19-23-28-34-42. Shadow-style 9 speed rd's work well with big cogs, too. The 17x34 and 17x42 ratios are great for really steep climbs. The 26x42 or 17x28 ratios are good for technical climbing. I am not f*#king around about low gearing. If I am descending or need to get somewhere, the 39x11-13-16-19 combos do the trick.
Avid Levers - 1st made in U.S. version?
Shimano DX BMX V-Brakes
Salsa Boosters
Kink BMX Purple Compressionless Brake Cable Housing
Kool Stop - red v-brake pads
Tires:
Panaracer Fire FR Pro 26x2.4 - front/Panaracer Fire XC Pro 26x2.1 - back.
Bolt-on Top-pull Deore Xt M737 front derailleur. Don't see many of these!
Chris King Headset
Cane Creek Rear Wheel
Mavic/Ariel Front Wheel - Never seen another Ariel Hub!
Titec Ithy's Saddle
Drivetrain
Salsa Boosters
Tires:
Chris King Headset
Titec Ithy's Saddle
