Is it necessary to coat the edges of tubless tires with water before mounting the tires? I saw mechanic installed the tires on my bike by applying a coat of water around its rim. Can I just mount it without putting water on the tire edges?
If you can get it mounted sans water, then no. The water was likely used as a lubricant to help get the tire mounted up. On UST Tires, I believe the use of tire levers for mounting/dismounting is frowned upon.Picard said:Is it necessary to coat the edges of tubless tires with water before mounting the tires? I saw mechanic installed the tires on my bike by applying a coat of water around its rim. Can I just mount it without putting water on the tire edges?
What is an air block? did you buy from specialized? Where did you buy the compress air tank ? Can I use the plain floor pump?borregokid said:I had trouble getting one of my first tubeless tires mounted and took it to a shop. I think the guy put some water around the edge, but the real secret to getting the tire mounted was the compressed air. I had a compressor but never thought about using one. I bought a set and one of the two leaked air from day one, eventually I put Specialized Air Lock inside which solved the problem. To get the tire seated also on the rim the compressed air is nice to really bring the pressure up quickly.
Just my experiences:Picard said:Is it necessary to coat the edges of tubless tires with water before mounting the tires? I saw mechanic installed the tires on my bike by applying a coat of water around its rim. Can I just mount it without putting water on the tire edges?
I happen to have only put in Stan's when changing tires, but I see no reason you couldn't deflate, add, and reinflate. I have only ever used a floor pump, personally, in four years of riding UST. I think I may have even used a hand pump a few times, but I don't remember.Picard said:Is it necessary to put stan sealant into the tube before inflating it? My tires are already inflated, can I deflate it and put in stan sealant then pump it up again. Will the tire inflate if I use floor pump ?
