After riding home 19mph into a headwind, 110 degree heat, High 280 percent assist my Yamaha PW-SE motor’s case was almost too hot to touch; 3 seconds to fingertip pain so probably around 140 degree case temperature. I don’t think this was at peak power; probably averaging 300 watts.
This much heat is mildly concerning to me; bearings are probably OK up to 180 degrees and nylon gears are heat-resistant, but the motor controller board is inside the case and probably cooking.
Yesterday I backed off a bit; very similar hot weather but I dropped a gear so 15mph, slighly higher cadence and Standard 190 percent assist. My personal comfort in the heat was about the same, but the motor temperature after the ride improved; there wasn’t a noticeable difference between the motor case and the bike’s frame.
To preserve motor longevity, I’ll be backing off a bit and gearing down in the summer heat; IIR losses in the motor means that fifty percent more torque is double the resistive heating. Spin more and slow down to avoid overheating.
I’m hoping to commute on the eBike throughout the summer; before the eBike I would avoid heat index condition of over 105; usually in Phoenix heat index is much below measured temperature.
