This is from the Enduro sSeals instructions for the Fox 36 talas rc2. Not sure what fork you have but you should check out the tech section here...
Enduro Tech
"32) Inject 15cc of multi-viscosity fully
synthetic motor oil into the bottom of
the TALAS side fork leg...
...The multi-viscosity, fully synthetic
motor oil we chose to use is made by
Amzoil®. Any other reputable brand is
acceptable. Note that Fox recommends
damper oil. Damper oil is OK, but does
not stick to the parts as well as the
mulit-viscosity synthetic motor oil."
So enduro seems to think it is fine, even preferable.
I haven't done this yet, but I'm planning on giving it a try when I re-build my wife's 36.
DRS
Edit to add: You may have better luck posting this in Shocks and Suspension.
