Apologies up front if this has been covered. Pro'ly has been...
So I was just cruising around the forum checkin out other folks rides. And I noticed that there seems to be quite a bit of variance in the pressure people are running in their Fox RPsomething-or-others. For example, I run 130psi in my RP23 on my large ML. I weigh 160 ready to ride. Enduro recently posted in the MotoLite Set-up Database thread that he runs 110psi in his RP23 on his Med. ML and he weighs in at 180lbs. (I'm assuming we're both going for the Titus recommended amount of sag.)
Why would there be a 20lb difference mine being the lower of the two and I weigh less? I understand that there's going to be some variance between the shox. Not every one is exactly the same with manufacturing tolerances etc.
simp
simp
