the difference in the geometry numbers has always been do to the location of the pivot. at least in the pre 2006 era, you could swap the chain stays. seems like every 2 weeks somebody is saying they will not fit and then we learn they fit.craigstr said:I was saying it would be $800 for the whole rear end, carbon seat stays included, but I looked on titus's site and the corresponding RX rear is about 1/4 inch shorter than the ML rear.
I say, get the friggin FR lowers. They work great. Let the sissy carbon stays to the XC racer guys!dulyebr said:"Yes the Racer X chainstay will fit on a Moto Lite. However it is not being offered individually as an aftermarket upgrade. It is being sold as a rear assembly kit with the carbon seat stays and will include hardware. The kit will retail for $710."
Jeff Titone
Account Manager/Inside Sales
Titus Cycles
800.858.4887 x.15
www.titusti.com
lessgears.lessgearsmorebeers said:I'm confused do riders want more clearance because the racer X chainstays are only accomodating to a 2.1-2.2" tire. Why would you need to go back to a smaller stay if everyone seems to be wanting more clearance. The Racer X according to the catalog is16.65" chainstay and the Motolite is 16.85" I'm not an engineer so i couldn't tell you if that matters but i would gues that it effects the geometry and where the stresses are placed on the different sections of the frame. I'm a firm beleiver in letting the designers tell me what will and what will not work on the bikes they designed.
thanks.dulyebr said:well put.
I emailed Jeff from Titus if he knew why they didn't spec the 2006 ML with new RX lowers - no response.
I haven't tried, but it's either gonna be very very tight at the bridge or it simply won't fit.tazdevl said:So looking after reading this thread... not sure of the answer. Will a 2.35 Nevegal fit on the rear if you have a F/R rear end?
that is a good question. I think it will. my enduro 2.4 fits but is really to tall. and can rub on the bridge. there was no width fit issue. that tire is a ballon and is to tall.tazdevl said:So looking after reading this thread... not sure of the answer. Will a 2.35 Nevegal fit on the rear if you have a F/R rear end?
Thanks for the scoop. Was going to put a Nevegal 2.35 on my HH tomorrow. Figured why bother if it wasn't going to fit. 2.24" Mutanoraptor has worked out well, but I need a bit more traction on some of my regular trails.dulyebr said:Charles from Hammerhead Bikes rides Blue Groove 2.35s on his Hammerhead with the FR lowers. And, according to Shiggy's site, the BG 2.35 is 2.41" while the Nevegal 2.35 measures 2.39".
As far as the casing height, which would be the important measure concerning the clearance at the seatstay bridge. The Nevegal 2.35 is 51.3mm high, which should be fine. I'm currently running a Specialized Adrenaline 2Bliss 2.0, which measures 51.6mm, and no problems at all.
By the way, the Spec Enduro 2.4 is 54.3mm in height - freakin' huge!
thanks for the info, that should mean that the 2.35 will clear the bridge by 3mm if Shiggy's site is correct.dulyebr said:Charles from Hammerhead Bikes rides Blue Groove 2.35s on his Hammerhead with the FR lowers. And, according to Shiggy's site, the BG 2.35 is 2.41" while the Nevegal 2.35 measures 2.39".
Nice. Those are the biggest tires I could ever imagine running on my Moto-lite. Good to know that they fit okay.tazdevl said:Small HH100X with FR rear... just put on the 2.35" Nevegal... seat bridge has 0.3" of clearance and 0.4" clearance from the tire to the chainstay.
