Setting tr
I recently got a Garmin Edge 530 and want to get the most accurate heart rate data as possible. What is the most accurate way to calculate my training zones? I have researched the basic method with your age for max hr, the hhr method and lactate threshold. Unfortunately I can't find any info showing which gives you the most accurate training zones. Any info is appreciated.
The age formula is for population average, it won’t tell you your actual max or determine your training zones.
hr varies with power output, but it also varies with fatigue, dehydration, core temp, etc. That means there’s some duration where hr is steady with power, and after that hr will drift upwards, and when and how much depends on you and your current fitness.
So, really, hr isn’t a perfect Way to determine your training zones, but it’s good within some time duration And state.
The important number isn’t your max but your lthr, your lactate threshold heart rate. There are some weird things that happen there. Thing about lt is that when you ride above that effort your hr will increase until you pop or slow down.
So, you can find your lthr by riding on a flat road with consistent wind. Warm up for 30 minutes then Ride faster and faster watching your hr carefully. Let hr stabilize at say 120, then increase effort until it stabilizes at 130, 140, etc. Just kiss those hr for 30 seconds, verify to yourself that you believe the effort is sustainable for 10-20 minutes, then increase. At some effort level you’ll be in pain and find you literally cannot stabilize hr for a minute or two, that hr only increases. Keep playing with speed until you find your highest sustainable hr.
Below lt you can sustain effort, above you cannot and hr will rise to max. With an erg mode power trainer you can find lthr precisely by ramping power. Be careful on a trainer that you have good fans, heat can make hr rise for same power output and so give different results than when actually riding.
Those are my words but I’m some chump, don’t listen to me. Here’s protocols and verbiage from a proper expert coach.
Note he calls out VT… ventilation threshold. Vt is real. I find breath is the best indicator of zone and doesn’t require any gadgets.
