That's unacceptable in a frame that costs that much. It's a warranty issue. Contact Ellsworth and have them make it right. This one should be easy to prove.Brannigan said:
That's unacceptable in a frame that costs that much. It's a warranty issue. Contact Ellsworth and have them make it right. This one should be easy to prove.Brannigan said:I've got a new 2004 ellsworth truth and i'm having problems with the seat tube scratching up my seatpost, i've cleaned inside and out, regreased yet its still doing it, which is a pain as i lower the seatpost when changing shocks (i got a Ti romic and a fox float) its leaving quite deep scores on my nice new thompson seatpost.
So is this a problem with 2004 ellsworth frames, it looks like its caused by the hole thats been put in at the seat tube and top tube for welding, so am i just going to have to buy a new seatpost and only use that one at my normal riding height and use the other when changing shocks?
Cleaned inside and out?Brannigan said:I've got a new 2004 ellsworth truth and i'm having problems with the seat tube scratching up my seatpost, i've cleaned inside and out, regreased yet its still doing it, which is a pain as i lower the seatpost when changing shocks (i got a Ti romic and a fox float) its leaving quite deep scores on my nice new thompson seatpost.
I'd take it back to where I bought the frame and let them [email protected] around with it. Maybe if a quick hit with a wire brush does the trick it'd be OK, but to go through running solvent down the tube...brushing...high pressure air....what a hassle.Brannigan said:hmm, i might have argued those points EW but since me and blower are both in the sunny UK i guess thats the proof, although it wasn't men in brown, it was some company called bax international, who make UPS and USPS look like saints!!!!
Anyway i'll get stuck in with a wire brush, i have 2 thomson seatposts so its not too much of a killer, i was just querying it due to this being my third ellsworth frame and the first to give me problems.
As for the shot/roto peening, i used to have to do that on stuff at my work, i remember pretty well the fact that the balls could get into places they weren't meant to, the only way of making sure it never got in there was to use blanking plates/plugs on every access to the internals of the component, then use the air hose to clean it up after, then after that it was a case of sticking the component into a petroleum pressure washer and after that a tank of trichloerethane vapour to clean it all up, i doubt ellsworths budget runs to that though, otherwise the frames would double in price to pay for the new kit.
What, Huffys?Trevor! said:Cleaned inside and out?
Did you lightly sand the inside of the tubing - some frames require that. .
