1 - 20 of 23 Posts
just another project to kill some time
remove rotors with a t25 torx
clean with rubbing alcohol, prep is key
mask off brake track and mounting holes
oops old can of white paint is no good
time for a trip, got some safety yellow
elaborate weather guard and wire setup. spray light coats and alternate strokes for each coat. i wait 5 mins between each coat. light spots are ok just remember light coats to avoid drips
drying, will add a few more coats later
remove tape, i was more concerned with masking off the backside of the mounting holes because i did not want any interference with the mounting.
inspecting the goods
put the screws back in
finished
I have the same frame and I love it! I've never seen a seat mount like that - what is it called?
I might go the other direction with my rotors and paint them black. I plan to black out my entire bike at some point and I might as well start with the rotors.
Nice work!
factory paint
I just installed a Rockshox Pike 454 with 20 mm thru axle. so I had to built a new front wheel. I also replace the rotor to fit the new hub. The Frame KHS AM2000, wheels Mavic D 321 and rotor XTR 8 " center lock are all factory painted semi flat gun metal grey.
1 - 20 of 23 Posts
