No problem at all with the reduced steering lock. Because the fork legs are offset forward at the crowns, you can still turn the bars close to 90 degrees. It's never been an issue on the trail.OnTheMoment said:I am, 6'2 with a ~35" inseam. I looked long and hard at that DUC32 but wanted to stick with the single crown. How Do you like the Maverick? I've been told it doesn't have any significan effect on how far you can turn the bars.
Yeah, I've been looking at the Maverick Tuning Chart, and also seen some other recommendations (I think MK_ had some good posts). I'm about 205 with gear and fairly aggressive, so I'm looking at settings down near the bottom of the chart. In addition to the damper settings, increasing the air spring oil volume will make it more progressive, and a stiffer negative spring is supposed to improve top-of-stroke compliance at higher air pressures.OnTheMoment said:By custom valving do you mean the custom shim stack reccomendations on the Maverick site? I talked to a guy from an LBS with a DUC on his MotoLite, he said that made a huge difference. What is the AtoC?
lol I should have been more specific, I know where the measurement is taken and what it effects, what is the actual numerical value for your Maverick?slackdaddy said:The a-c is the axle-to-crown measurement. That and the static sag determines the ride height, which affects your head and seat angles, front-to-rear weight distribution, etc.
Clearly the shots should be taken at the rider, not the bike.OnTheMoment said:Brian, for crying out loud post something or I'll take some pot shots at that expensive bike of yours. As for light on the bike and daylight between the ground and the tires maybe after you get fixed up if you've got a camera we could arrange something.
