I'm still working out fit and adjustments for my Hollowpoint, and have a couple of questions for those of you who have been riding them for awhile (and Ska Todd):
If the Fox Float R AVA is most linear on its biggest volume setting, and therefore more like a coil shock (from Fox's website), why is the recommended setup to have the AVA dialed all the way in? (I ask this partly because I know the stock HP Sport came with a Vanilla.) I like the shock; I have it set a little more than half closed and it's great on fast, loose, bumpy descents, but it feels a little too plush on climbs/flats (set at 1/3 sag), and I can't stand in the saddle. Any info on how to tweak this setup?
Does anyone know why Iron Horse ships the HP with almost 2" of headset spacers? I'm 6' 190# with about a 32.5 inseam and bought a large because it felt best on the test ride, but I'm probably between a large and a medium (TT length is about an inch longer than my hardtail, but that bike has a more racing geometry and I wanted something a little longer). Would it mess up the geometry to remove most or all of the spacers and lower the bar a bit? With the risers I feel a little high in the front (with fork at 100mm).
