Replacing the stock BB on my ML. I'm running a Chris King sleeve with the stock BB. I also have a Chris King BB on a non-fat SS that I can borrow.
Bike is stock with MWOD crank.
Questions...
1. Can I use the CK bearing cups along with the CK sleeve in the ML?
2. If yes to #1, will everything space out the same? The stock BB has tapered "spacers" between the outside of the bearing cup and the inside of the crank arm. Do I need to use the tapered spacers with the King BB?
3. I have a tool for GXP bottom brackets. Will it work on the CK cups?
Thanks.
Questions...
Thanks.
