thanks for your help. Does anyone know if the 2000 model is upgradable to the hscv cartridges?rpl3000 said:????- 2000 -- I think these are ported dampers, 170mm
2001- 2002 -- dual hscv carts, 9 lbs, 170mm travel
2003 -up -- moto carts, 200 mm, 11 lbs
my 2 cents, '02 is the best year to get
No.rpl3000 said:????- 2000 -- I think these are ported dampers, 170mm
why did you stop using your old Jm. account with over 7K posts?Jayem said:No.
-1999 Dual cartridge dampers, both rebound-adjustable. 175mm of travel.
-2000 One compression- adjustable cartridge, and one rebound-adjustable. Some users fond that the compression-adjustable cartridge made the fork feel harsh, some users drilled out the compression cartridge to allow free oil flow.
-2001 Dual HSCV cartridges, both rebound-adjustable. Virtually same as 1999, cartridge differences very small, still the same basic thing HSCV=cartridge damper
-2002 Dual HSCV Cartridges, both rebound-adjustable. Addition of bleed ports on top caps for
-2003+ Shiver MX cartridge damper, basically a cartridge damper, but much more advanced. 200mm of travel, new chassi.
If you find an 1999, 2001 or 2002, replace the oil, seals and possibly bushings. If the legs are not all scratched up, you'll usually end up with a killer fork after doing these things.
What do you mean "convertable"??mtn_man2 said:I'm still curious if the 2000 is convertible since there are a few for sale on ebay right now.
Thanks again.
Marzocchi didnt call the damping HSCV before 2001, correct?Jayem said:What do you mean "convertable"??
If marzocchi has any Monster T cartridges, you could retrofit a rebound-adjustable cartridge in there to replace the compression cartridge. Or you could just drill out the compression cartridge and you'd still have a pretty good fork. The rebound-adjustable catridges are basically the same as "HSCV", but if you want to put two new cartridges in there from an 02 monster, it's definitely possible, and only a matter of if marzocchi has some. They usually do have some of these parts, but it's getting scare for some of the older forks.
That's what I was thinking. Sorry for not being clearer. I guess I'll talk to Marz tomorrow and see what could be done.Jayem said:What do you mean "convertable"??
No. I was trying to avoid the term that they used because it is confusing.[email protected] said:Marzocchi didnt call the damping HSCV before 2001, correct?
mtn_man2 said:Jayem Thanks for all of the info. I knew I had seen it before. I guess it's the '02 model. I'm still curious if the 2000 is convertible since there are a few for sale on ebay right now. Thanks again.[/QUOTE said:I got a 2000 last fall. What I did was something Brian from Marzocchi suggested -- I put a lighter oil in the comression damping leg. I rebuilt it with new seals, 7.5w in the rebound side and 5w in the compression side.
I love this fork. Plush, no flex at all, and I've yet to bottom it out. I may try drilling out the compression side, but frankly, I don't see the need.
