Maybe it's just me but:
The monster has 200mm of travel so I have that much stanchion exposed below the lower crown.
The manual says the crowns must be clamped on the part of the stanchion that is larger in diameter.
If i leave 200mm exposed below the lower crown then the lower crown is partially clamped on the larger diameter area of the stanchion but about a 1/4" of the lower crown is on the smaller diameter area of the stanchion.
Does this matter? Did what I said even make any sense?
I guess the lower crown is clamped good enough, I hope so because i know i don't want to hit the seals onto the lower crown when i use all my travel or worse, hit the tire on the crown
