Just finished a rideable version of my monocog with gears on it. I've been riding it to do errands and just needed more gears. I'm starting longer rides too and I want to see if a bailout gear will let me ride longer. I kind of did this with parts that I could get cheap. If I like gears I'm going to order up a wheel with a real hone hub, cogs from a new cassette and probably Paul Thumbies. It actually only has 5 usable gears. the 32/14 combo is like going from your granny gear to your smallest cog and the chainline doesn't like that. I've ridden it around the block extensively but heading out right now on a ride on the trails. Any Comments and Suggestions are welcome. This is a first draft so if you see a problem let me know.
Suntour friction shifter
Shimano Hone Derailleur
32 tooth stock chainring
36 tooth Blackspire chainring will keep the chain on the 32 tooth. I only use this ring on the street
n-gear Jumpstop
3 rear cogs on the Monocog Hub
24t bailout.
20t
15t screw-on cog
Thanks to everyone on the forums. I had a crapload of stupid questions and everyone was very cool about answering them. This is a great place to get information especially if you're putting unorthodox parts on it. Here are some pics.
n-gear Jumpstop
24t bailout.
20t
15t screw-on cog
