I have a strange problem that I can't wrap my mind around. After having had Vs on my bike for years, I decided to go with disks for the new bike build, and being a good old weight weenie I ended up getting Hope Mono Minis.
The install was a breeze, and after 1-2 miles of riding they broke in and the breaking is fantastic. But... I'm having strangest leaking problem. One of them (the front brake) is weeping fluid. As far as I can tell it's leaking from under the master cap.
The strange thing is that it's leaking even when the bike is just sitting in a car. It's a truck and I have a bike rack made int he back, so the bike is upright, not on the side or upside-down, so that's not the problem.
For the life of me I don't understandd why the fluid would leak out _UP_ when the brakes are not used and there is no pressure in the system.
When they arrived that level body was wet with fluid and upon later inspection it was low on the fluid, so I thought that maybe the air in the system was expending, we had few hot days here, and creating enough pressure to force the fluid out. But the other day I re-bled them brakes and re-filled with the fluid to the top, so there is no air in there at all, but they still keep leaking.
I called Hope customer Service, and they gladly sent me a new diaphragm (it's in the mail), so I will see if the original one was defective and wasn't creating a good seal.
But even if that's the case, why would the fluid leak up?
Especially puzzling, because the other one, the rear, is flawless and has not a hint of this problem.
If anyone experinced similar problem, or has any ideas, or explanation, I'm all ears.
Dmitri
Dmitri
