Yawn.
Wake me up when a real, actual, brand, makes one that isn't designed to fail in 50 hours ride time....
And yet you won't pass up an opportunity to show how much of an asshole you are to brands offering alternatives to overpriced garbage like Cannondale does eh?Yawn.
You yourself could just keep your trap shut and ignore posts that don't interest you. But no....Cannondale IS overpriced garbage, so you'll have to do better than that.
Ditto for most of the brands now. Prices are insane, and what you get for it, hasn't truly improved in 15 years in any appreciable way that viscerally impacts rider enjoyment, safety or pleasure, it just makes the cash flow more heavily to the brands investors.
Yet, just because one end of the spectrum is at fault for something, doesn't give the opposite end of the spectrum, an excuse to run free without critique, and junk brands that make and sell garbage designed to be thrown out after short term use, are a wasteful affront to common sense, functional value, and mother earth.
They do not respresent value for those without deep pockets (as they try to position themselves as doing), they make said customer spend more money, more often, on repairs, and outright replacements, than buying a basic, solid, well engineered bike.
Though, why you're wasting your personal time, shilling the industries excrement, is beyond me, seems with your hyper analytical mind (meant as a compliment), you could find more interesting things to write novellas about....
I didn't have any problems with my 39# Schwinn Sting-Ray back in the day...Came here thinking this would be 1 thread with nothing to fight about. Silly me. Good write up. WTF on that 36t ring and dayum! @ 38lbs. Anyone have firsthand knowledge of a kid actually riding one of these?
The only "disposable" parts in the stock build are the reflectors and the handlebar (although it does a good job as a lug wrench breaker bar extension for a car). Nothing on the bike is going to just magically fail in 50 hours as MoronCycleSmith seems to believe. Pretty much all the parts you'd need to upgrade on one can be bought from Amazon or AliExpress, or even FB marketplace and pinkbike. Except for a couple bits I had already from having upgraded so many Northrock XCFs everything else in the one I upgraded I got in under 48hrs from local shops and Amazon. The wheels aren't heavy. They're lighter than the wheels on many 26er fat bikes that sell for close to 2k. Tires weights are competitive to some of the best folding bead 26 x 4.0 tires. The stock steel fork is still lighter than the one on the CCM Brut and Northrock XCF. The one I upgraded lost over a pound AND improved the gearing to a 34T ring and 14-42 cogset which is plenty low enough for the typical rolling terrain of most of Ontario.I considered one of these for my 8 year old son but decided against it based on the sheer weight of it, gearing, heavy wheels and tires and disposable parts.
I also don't have the spare parts to upgrade it for him either.
38 pound bike for my 80 pound son, I weigh 220 and ride a 32'ish pound Yukon
RIGHT...and the fact you wouldn't fucking know any of these details if i hadn't objectively disected one in the first place ?! ..I'm not going to get into a debate with you on this, I realize you resell these things so you're not going to be very objective anyway.
Only the BB is lacking in seals on the cup ends, and if you own a grease gun...this also makes it easy to stuff grease into the cups without even removing them. The headset is sealed fine it just needs more grease in it. But as I said in the writeup...new BB cups with seals are available and easily solves that problem (for under $10 no less). If you're incapable of servicing hub, headset and bottom bracket bearings you probably shouldn't be buying bikes from anywhere but a bicycle store which will do the proper service and assembly for you. Most bike stores are all too happy to take money from mechanically inept people.You mentioned the lack of seals and grease on the BB and headset, one would expect the parts to fail without proper grease.
Steel bars, post and cranks...you said yourself to use it as a prybar...so disposable. What could I resell it for? $5?
A 3.5 pound steel fork on a 24 inch wheeled bike is an anchor any way you slice it.
95 mm inner width wheels with 36 spokes for a 24 x 4 inch tire are overkill and needlessly added weight for an 80 pound kid to ride in the snow. Plenty of people are running 27.5 x 3.8 on 50-60 mm rims. Probably impossible to go tubeless too.
Again with repeating information you didn't have until I reviewed the bike. Do you even have an undestanding of just what kids fat and plus tires bikes from other brands actually weigh. Because under 38 pounds is reasonable for this price point ($380 in store) of a fat bike. The next cheapest alternative available in Canada is $900 (before tax) for the 24 inch Moose which is about 36 pounds with worse tires and tubes and only marginally better gearing (a 11-34 cogset and 28T ring).Likewise steel bars, post, cranks, tubes etc. 38 pounds is 38 pounds. Bad gearing etc makes it even worse and that's before you even try to ride it on snow.
I had the handlebar, brake levers ,crankset and chain that I used in my parts already but as I said, everything else I sourced in 2 days from local shops or Amazon. Now because I was in a hurry to finish the upgrades and get it out into the world in some new owners hands, I paid more for bits than if I'd taken my time with it. Also what I pay for parts isn't going to be what others pay for them, nor does what I did need to be as extensive to improve the bike. But I sold the one above in the photos for $750 and made enough of a profit to pay myself for my labour time spent on it. If I had nothing at all, and wasn't in a hurry, then everything can be gotten from AliExpress in a month and for less money than I paid on Amazon or locally.So basically, most of the parts need to be replaced
The fact you have a garage full of parts makes it easily upgradeable.
So while the $389 might seem appealing....it would really be $700+ to get it setup properly, which is what you sold your built one for right?
Then JUST PASS on the whole thread without commenting. Don't be a nimrod like Moroncyclesmith spewing nonsense. As to the reverse fork... I've seen that happen at local bike stores also. Bad bike mechanics aren't exclusive to box stores.So yeah, it was a pass for me.
I don't know what a Jasper would be in the USA besides "cheaper" given the different dollar values. Costco USA's website doesn't even show the bike as available while Costco Canada's website does. Its possible Costco USA doesn't even stock the model at all. Maybe Mongoose won't make it available to them since it would take sales away from the Argus Trail 24. Mongoose's international website doesn't show the same fat bike options their USA website offers.I appreciate the write up.
Based on the review and needed upgrades, seems a better option would be a used Specialized Fat Boy 24 They pop used on Marketplace pretty often for $600-$1000.
It's funny your sig says this when the complete opposite is true.RIGHT...and the fact you wouldn't fucking know any of these details if i hadn't objectively disected one in the first place ?! ..
The steel parts are heavy...they're not going to break though and aren't disposable unless you choose to replace them. I use the bars as leverage devices for other tools or donate them to the local bike co-op, but the post and cranks will sell just fine to other people looking for spares to do repairs of other bikes. If you think a 3.5 pound fork is heavy for a 24 inch fat wheel you clearly don't know what most 24 inch kids bike forks actually weigh, nor what most steel fat bike forks weigh for 26 inch wheels. As to the rim width.. more floatation is actually a good thing with fat bikes. That some people are willing to put up with shrinking their tires below the claimed sizes stuffing them onto narrow rims doesn't mean its actually the most efficient way to build a fat bike. And to tubeless... I don't know where you live in the country, but Ottawa routinely sees temperatures below -25C and most sealants don't really like that temperature, but no its not impossible to go tubeless on these rims. Its just impractical given the cost of valves, tape and sealant today compared to just buying some lighter tubes.
They do not respresent value for those without deep pockets (as they try to position themselves as doing), they make said customer spend more money, more often, on repairs, and outright replacements, than buying a basic, solid, well engineered bike.Cannondale IS overpriced garbage, so you'll have to do better than that.
Ditto for most of the brands now. Prices are insane, and what you get for it, hasn't truly improved in 15 years in any appreciable way that viscerally impacts rider enjoyment, safety or pleasure, it just mae cash flow more heavily to the brands investors.
