i happen to have a small problem...
i recently bought a legend mk2, and i am just blown away about how well it pedals... actually better than my rune i think... have a 36t chainring on it, and damper is a RC4...
of course i know that the rune pedalling performance is down to my not-optimal chainring choice... it is not bad at all, just i have the feeling that i could do something to make it even better...
currently i run a 22-36-rr combo...
the 22t ring is for long mountain climbs, i dont think i can get away without it.
do you guys think, it would be worth trying to replace the 36 with a 32 ring, and use it almost always, and only use the 22t ring for long, steep fireroad climbs?
does anyone have a hint on which REAL 32t bashguard to use? i want to save a bit of weight as well here if possible...
or is it a stupid idea after all?
i dont want to go to 1x10 since i still have 9-speed cassettes in reserve... so that will remain 11-34 9-speed in the back...
other thing, i started using the proper SAG after i found out that the 15-20% stated on the homepage were a missunderstanding... running little more than 25% sag now... but on the DHX air, i tend to bottom out a little bit now, even on the hometrails... i already put the volume of the piggyback to the minimum...
i have heared, that it works well on the dhx to put a little additional oil into the main chamber to improove the bottom-out resistance...any thoughts on that?
i have fiddled a bit with the pressure in the piggyback, but that doesnt seem to solve the bottoming... only makes it more unsensitive...
i dont want another damper right now, and i know that some things can be done with the dhx air, but i am just no suspension expert... more of the set-and-forget typ of guy... dont know to much about how the settings interact, and maybe somebaody has some advice for me...
