Bob's Build
I know it's a little light for the frame, but I'm putting a spare '03 XTR gruppo on. I need to see if I can get an 8' front rotor and adaptor. Fox said that all their '05 shocks will take an 8' rotor, by the way.
The rest of the build is as follows:
2005 Fox TALAS RLC (90-130 mm travel), black
King headset and ISO disc hubs, black
Thomson post and stem, haven't decided the stem length, yet, probably 120-130 mm 5 degree with about 20 mm of spacers
Easton Monkey Lite bar
WTB grips
WTB SST 98 Ti saddle
Shimano PD-646 pedals
XT 11-34 cassette
I've got to look at tire options; I hope WTB Motoraptor 2.4's fit
Rims will be Mavic XM 819 Disc for a tubeless set and probably WTB Laserdisc DH's for the other. I need to check frame clearance for the WTB rims with the Motoraptors.
I do build all my wheels, and I've started using mixed spokes on the same wheel. The tubeless wheel, for example will have 2.0/1.8 mm butted DT spokes with brass nipples on the entire rear and on the front brake pulling side, with 1.8/1.6 mm spokes and brass nipples on the other 3 spoke positons of the front wheel (nondrive rearward facing and both drive side positions).
The other wheelset is all 2.0/1.8/brass since it's for heavy use. I had a wheelset with those same components on my Turner RFX and they were absolutely bombproof.
My Blur's wheelset will also fit in case I want to go stupid light. It has Mavic 317's. The front tire has 2.0/1.8/brass, 1.8/1.6/brass and 2.0/1.5/alloy (revolutions). I always use brass nips on the pulling postions.
Fox told me today that the 600# spring I need will be at least another week (sigh).
