1 - 2 of 2 Posts
Here is how the blackspire stinger works with the DT.
Lighter setup over E13 DRS. for use with dual ring.
The modification is mentioned here:
Noel on Building a Lighter Delirium T
https://forums.mtbr.com/showpost.php?p=4982779&postcount=7
Here is how I did it.
1.. bolt up the e-type Front Der and but in the BB shell.
2. screw the blackspire in loosely and get in general position. Guide: My pinky fit between the roller and chainstay. (Thanks for the tip Dom!)
3. Mark the back of the stinger where it interferes with the e-type plate. (I used a scribe. also could probably use a nail or brad or needle)
4. Remove everything
5. Cut the blackspire stinger where you marked it.
6. Bolt it up. Use some locktite!!
Pic:
Hope that helps.
1 - 2 of 2 Posts
