Happy New Year!
The past year I started working with Nick at Neuhaus Metalworks to design and build some pretty cool bikes. We have made a lot of progress, so I thought it would be good to do a recap to benchmark our progress and serve as a reference/inspiration for other framebuilders.
To give some background, Nick is the framebuilder, I am the armchair engineer/CAD monkey. We work together to figure things out. I bring his bikeCAD into the 3D CAD world, handle the 3D printing process, then he builds the frames.
3D Printing:
Over the past year, we spent several hundred hours and several thousands of dollars designing and printing prototypes. I found that the design freedom of 3D printing has really enabled some really cool workflows.
After all the expensive dust settled, I think 3D printing is the future of custom framebuilding. The only limiting factor is people’s CAD skills. Better fire up those Fusion360 tutorials. I think 3D printing is more accessible than most people realize.
How to build a rear end:
Chainring and tire clearance:
One of the most challenging aspects of designing a modern mountain bike is getting enough clearance for the tires. The worst pinch point happens at the chainstay, between the tire and the chainring.
These are the clearances I design to:
Shimano’s are not published but are floating around. They are slightly more conservative than SRAM's
Tire Clearances:
Go/no go based on 6mm tire clearance, 6.5mm thick yoke, and 2mm chainring clearance.
*Your mileage will vary without a yoke, it all depends on how much you dimple the stays and the exact profile of your tire.
The chainstay is constructed with .75x.035in tubing with a single 11deg bend. I have found all pre-made chainstays are a trap.
Seat tube Design:
The seat tube is made with straight 1.375x.035” Chromoly tubing a welded on topper for several reasons:
There are two things you need the seattube to do:
Even in an edge case, it gives enough clearance for a 29x2.6
A few tips:
I don’t have much to say about seatstays, except that the material is super limited at the moment. Single bends are cool, S bends are cool too.
Typical Seatstay Tubes:
Design Examples :
Here are a few construction drawings of a Solstice. Hopefully, they can help shed some light on the design and fabrication process.
These are construction drawings, so some dimensions are missing. For example, the wall thicknesses and butts are specified by Nick’s experience and expertise.
Medium:
Large:
Moving forwards, I am going to make an effort to put more information and answer questions on this forum. I have learned a lot from the mid-school builders that have taken the time to document and publish their processes. I hope to do the same and encourage others to do so as well. Having a positive, open, and inclusive community benefits us all.
3D Printing:
- Tire clearance: 6mm on each side
- Chainring clearance: 2mm
Tire Clearances:
Wheel and Tire | Chainstay | 52mm (boost) | 55mm (mid boost?) | 56.5mm (super boost) |
29x2.6 | 420 | yes | yes | yes |
29x2.8 | 420 | no (1.5mm short) | yes | yes |
29x3.0 | 420 | no | no (.3mm short) | yes |
29x2.6 without yoke* | 440 32t chainring | yes | yes | yes |
27.5x3.0 without yoke* | 430 32t chainring | yes | yes | yes |
29x2.4 without yoke* | 430 32t chainring | yes | yes | yes |
Seat tube Design:
- availability
- they allow for 31.6 droppers
- the thick topper distorts less and is easier to ream
- the thick topper reinforces the TT to ST junction
- You want to clear the tire
- You want the saddle to be in the right spot for pedaling
- offset
- actual seat tube angle
A few tips:
- It is better to minimize the offset. large offsets cause the seat tube to be slacker at full saddle extension
- Taller riders tend to need steeper seat tube angles
- shorter riders tend to need slacker angles
- 1/2x.035
- 9/16x.035
- 5/8x.035
Design Examples :
Medium:
Large:
