tartosuc said:
Hi,
With all the threads about rear shock i'm still confused on what to choose for my 05 mkiii..
for thoses of you that have exeprimented with rear shocks,(broncbuster derby e.t.c.) what are the best choices in your opinion and why?
thanks
You should factor in the terrain and what type riding you are doing.
Also the RP23 may not be the best choice for larger riders. I weight a buck-eighty.
I ride all mountain mostly w/some XC. Having only the Fifth to compare it to.
The RP23 is much much meaner. More in this thread:
http://forums.mtbr.com/showthread.php?t=251138
All aftermarket Float shocks including the RP23 have medium valving. This will not affect the ProPedal when in the "off" position. Meaning the RP23 in the off position is already in the lowest setting possible by fox.
You could try calling Fox to see if you can order a Float R set to minimum or IH may be able to hook you up. No huge advantage going with the RP23 over the Float R set to minimum, if you can get one. I do use the Propedal first setting occasionally though.
If that fails Fox advised the RP23 is basically the same in the open position as the '07 OE Float for IH set to minimum.
Greg and Derby have way more experience than I do with other shocks. In part factor our weights and ride specifics if similar to yours.
