Well I'm going to be lazy here and not do an actual Forum search, but I swear I've seen more than one thread with _dw chiming in about optimal gearing for each different DW Link bikes.saturnine said:
I ran a 22/38 setup on my Mojo (non-HD) and it seemed to work fine. My butt/legs and body couldn't tell that the bike wasn't working optimally with that set up.
Plus, what Ibis/_dw are refering to only effects the bike when seated and/or climbing. Once you stand up or take tension off the chain it doesn't matter if you're running it in the granny gear or only in the 'big ring.'
One thing I've noticed on the DW Link bikes I've owned, as well as the VPP and VPP2 bikes, is that all that linkage prefers to be ridden in the middle ring-regardless of what tooth. I get the impression that those bikes seem to 'bob' quite a bit more when in the granny gear-at least it's more noticeable.
