1 - 4 of 4 Posts
I have FSA zs56/zs44 cups in my frame and dropped new Cane Creek bearings in but now the fork binds with even a small amount of tension on the pre load bolt. The clearance on the top cap is still around 3mm. I can’t think what it could be other than the cups?
Thanks in advance for any help.
damned rocks...
Try to remove the top cap, install a stem spacer instead of the top cap, apply some preload and see it it binds.
When mismatching headset components even the seals may cause interference.
I have FSA zs56/zs44 cups in my frame and dropped new Cane Creek bearings in but now the fork binds with even a small amount of tension on the pre load bolt. The clearance on the top cap is still around 3mm. I can't think what it could be other than the cups?
Some of the bearings have different angles and will not seat properly into another manufacturers cup. I tried something similar with a Cane Creek and a Banshee headset (not sure who made the headset). The bearing would not fit properly in the Banshee cup. I had to remove the cup and use the Cane Creek one.
Your best but is to punch out the existing cup and press in a CC one.
Discussion Starter · #4 ·
Yup this was the problem, works great with the proper cups. Thank you!
1 - 4 of 4 Posts
