Check the chain stretch with a gauge. Muddy rides grind TF outta drivetrains.
Bad chains ruin cassettes and chainrings. Treat them as maintenance items and replace when stretched or very very close to stretched (if big ride/event coming up etc.) and your life will be much more pleasant out on the trails... 😅Will check it. Thanks. I also suspect #2 cog has worn out since the chain shifts fine on all gears except going from #3 to #2. The teeth where it suppose to pick-up the chain are a bit worn.
Also, the problem worsen when i engage the clutch.
and bearings.Muddy rides grind TF outta drivetrains.
so helpful and non judgmental in a few short lines, nice workPerhaps much better to not ride muddy trails.
I bet the OP is not one who maintains the trail.
