1 - 6 of 6 Posts
FleshwoundGravityResearch
Has anyone upgraded to a different ride kit on their Minute 3? Does anyone know what the original ride kit is, ie. firm, medium or soft? If so, what were the results?
I could be wrong, but I thought the Minute 3 is air sprung, so no spring kit change needed.
The Minute 1 is coil with adjustable travel
The Minute 2 is air, but fixed travel at 100 or 130 models
The Minute 3 is air with adjustable travel
Discussion Starter · #3 · (Edited)
Yeah, it is air (I do have one), but as you can see...
MINUTE 3:00
Kit Description Kit Kit #
SPV Volume Control Assembly A 85-5871
Minute SPV Rebound Damping Assembly B 85-5872
Minute Two/Three Air Cap Adjuster Assy. C 85-5873
Minute Crown Steerer Leg Assembly - Minute Three 100 D 85-5951
Minute Outer Casting Assembly STD - Integrated Black E 85-5953
Minute Outer Casting Assembly NB - Integrated Black E 85-5952
Minute Outer Casting Assembly STD -Matte Black E 85-5876
Minute Outer Casting Assembly NB -Matte Black E 85-5878
Minute Outer Casting Assembly STD - Matte Grey E 85-5877
Minute Outer Casting Assembly NB - Matte Grey E 85-5879
Minute Sticker Kit - Black F 85-5862
Minute Sticker Kit - Silver F 85-5861
Minute Two (130)/Three Ride Kit - Soft G 85-5882
Minute Two (130)/Three Ride Kit - Medium G 85-5885
Minute Two (130)/Three Ride Kit - Firm G 85-5887
Minute Three (100/130) Rapid Travel 1 Assembly H 85-5891
Minute Two/Three (130mm) Air Push Rod Assembly H 85-5956
Minute Knob Kit I 85-5893
Skareb/Black/Minute Air Piston Kit K 85-5266
Minute Bumper Kit K 85-5894
Minute/Black Seal Kit K 85-5281
Black/Minute Bushing Kit K 85-5321
Minute O-Ring Kit K 85-5895
Minute 3 Schematics LINK
Give Manitou a call, the fellas there are really helpful and you'll the answer straight from the horse's mouth.
I ride a Minute 1 with comes with the medium spring, as do most forks in stock form.
They do make ride kits for the air forks (2 and 3). I installed the firm ride kit in my Minute 3 and it makes a noticeable difference as the fork nears the last 2 inches of travel as the spring is the bottom out of the travel. I find that the fork works much better for me after the kit was installed as I weigh 220 and the kit was only $20 from LBS. A good excuse to rip the fork lowers off and change fluid too.
Downside is that if you lock the fork down to the 4" mode, it is nearly locked out as the ride kit is compressed in the lockout therefore compressing a stiffer spring than stock. The fork can be further compressed when locked down, but it takes a good shove to get it going so it is road climb only in my book.
1 - 6 of 6 Posts
