the rotor is certainly easily cleaned, the brake pads maybe. I have had the best success with heavy duty spray-type brake cleaner available from auto supply stores. the solvents in the brake cleaner are way harsher than the alcohol, and will degrease and dry quicker. I don't know if I would recommend Varsol or other paint thinner type solvents for cleaning brakes, as many of them leave an oily residue. Some have tried burning the oil out with a torch, with varied success ( I felt the brake cleaner worked better for me) ( uhh - that would be with the pads off the bike and on a non flamable surface BTW
) Good luck - worse case, you have to get new pads....... and be more careful next time
