I have a square taper Middleburn crankset I am going to install and it uses their self-extracting crank bolts.
Is a specail tool required to screw in the threaded "cap" that screws into the crank arm after the washer and crank bolt are installed? The cap has six tiny indents in it that looks like a tool would fit into them. Should loctite be used to hold the cap in the crank arms?
